high idle?
Old Jun 12, 2005 | 10:01 PM
76hi-boy's Avatar
76hi-boy
high idle?
my 77 f150(money pit/wiring disaster) has a 351m with a 4 barel intake and carb swapped on and the idle seems too high but when i start it and put it in gear it dies so i have to lightly hold the brake put it in gear and kind of take off real quick or it will die. any suggestions?
Old Jun 13, 2005 | 09:44 AM
73Custom's Avatar
73Custom
First check for vacuum leaks. Check all the hoses for cracks, replace any that are cracked, hard or brittle. Use carb cleaner with engine running spray around base of carb and where intake meets head - if motor revs, there is a leak. Also check the timing. Let us know what you find.
Marty
Old Jun 13, 2005 | 09:48 AM
TxBrokenarrow's Avatar
TxBrokenarrow
sounds like a vacume leak..get yourself some carb cleaner spray and spray it around the carb and intake manifold to see if it changes the idle.also check your vacume hoses...most of the time if you changed intake manifold and carb the intake will be the problem..so my holley carb pamphlet says.a vacume leak will cause high idle.then you should be able to adjust the choke and idle..good luck..let us know what happens
mustangnewby
Aug 19, 2014 02:01 PM
ConnorBrown
Aug 27, 2012 05:56 PM
vboxingguy
Apr 5, 2012 09:51 AM
magneto259
1983 - 2012 Ranger & B-Series
15
Jan 14, 2012 01:56 PM
ford-lover1995
22
Oct 20, 2011 04:37 PM
