Sponsored by: Real Truck
radio problems
Old Jun 12, 2005 | 08:07 AM
ditchbanger's Avatar
ditchbanger
radio problems
I have a 2001 f-250 lariat. My fm sometime doesn't work. Sometimes it crackles other times it just doesn't get a station. Other times it works fine. The cd player works fine. I checked the antenna wire and it is all the way in.
What else should I check before I take it in?
Old Jun 12, 2005 | 08:38 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jun 12, 2005 | 09:05 PM
nodakford's Avatar
nodakford
Check the antenna ground that it is good , and make sure there are no connections loose. That's all I can think of.
