My son's 1991 Sport will drain the battery in a couple of days if it is not run. I've narrowed the search to the EEC fuse in the engine compartment. When I remove this fuse, everything is fine...no battery drain. When I remove and install the fuse, with the key off, I can hear the fuel pump relay cycle on and off. Could this be causing the battery to drain? I have replaced the fuel relay with no change. Is it in the EEC module? "We" are getting tired of jumping the car every other day... Thanks for a great forum!
