Changing/torque spark plugs
HOW do you get at the plugs? I am used to looking at an engine, pulling a plug wire and taking care of the plug. This is my 1st V10 and I'm just a little confused on where everything....
Thanks
Chris
Thanks
Chris
you have a cop engine or plainly put it's coil over plug, remove each coil the spark plugs are under each one. be care full and use a torqe wrench so each plug is properly replaced and you don't cause your self a plug blow out. we have a few threads you can find useing the search funtion.
good luck the rear right ones are the worst
