Modular V10 (6.8l)
Throttle body question
Old Jun 10, 2005 | 02:42 PM
PurerockRacing's Avatar
PurerockRacing
Question Throttle body question
sorry if this is a duplication, but I couldn't find the thread I read before about the different types of throttle bodies. I have a 2001 F350, V10 of course. I bought the Poweraid throttle body spacer that has 2 holes in it (for the twin bore throttle body). However looking at my TB, it appears to be a single bore type, with one single oval shaped butterfly. Is there in fact 2 different types of throttle bodies??? Seeing how the spacer I got looks to be made for a twin bore type, I can't see it helping at all on a single bore type. Anyone???
Old Jun 10, 2005 | 04:28 PM
V10KLZZ71S's Avatar
V10KLZZ71S
Stock is twin 57 mm.If it's a single it must have been changed, probaly an AccuFab tb.Now as far as the spacer is concerned if you remove it you will see an improvement,some disagree, but I think they are snake oil.I have a BBK twin 65mm and it works great with a noticable improvement.If you do have the Accufab, the spacer is hendering the bigger tb because the spacer is designed to work with the stock tb.
Old Jun 11, 2005 | 04:51 AM
HeavyAssault's Avatar
HeavyAssault
PureRock: What year is your truck?
Old Jun 11, 2005 | 05:15 AM
Monsta's Avatar
Monsta
Sit. Stay.
Check his sig. It's an 01 F350.
Old Jun 11, 2005 | 05:17 AM
HeavyAssault
That's how you do that...I'm used to seeing it in the border, not a floating box when you hover over the word.
Old Jun 11, 2005 | 11:23 AM
PurerockRacing
I am going to re-check this today, I'll let you know what I find out. Oh yeah, I thought my truck was completely stock when I got it. Only 44k miles on it!
Old Jun 11, 2005 | 12:48 PM
MARZ06's Avatar
MARZ06
V10KL....how did you make the throttle cable fit with the BBK TB? I installed one (1711), and the damn cable had too much slack. Couldn't figure out how to correct the problem so ended up pulling the TB off and returning it.
