NEED HELP!
Old Dec 1, 1999 | 01:52 PM
duke's Avatar
duke
NEED HELP!
How do i get white shoe polish off of my truck?
Old Dec 1, 1999 | 06:37 PM
Tom Cullen
Guest
Posts: n/a
NEED HELP!
If the shoe polish is on the windshields you can use carb cleaner to loosen the poslish up then clean it up with a good window cleaner before it dries up again.
Old Dec 2, 1999 | 01:47 PM
duke's Avatar
duke
NEED HELP!
what if its on the body?
Old Dec 2, 1999 | 03:02 PM
Tom Cullen
Guest
Posts: n/a
NEED HELP!
Don't use the carb cleaner on the body, cause it can really mess up a paint job. Try WD-40. It is supposed to be good for taking road tar off, so it might work. Will probably take alot of scrubbing, whatever you use. hope this helps
Old Dec 2, 1999 | 11:32 PM
Jay's Avatar
Jay
NEED HELP!
You can use laquer thinner to remove the polish. Put a small amount on a rag(do not drench rag)and wipe down ereas in need of removal.You can use rubbing compound also ( it will require a little more elbow grease)After you have removed the polish be sure to wax the areas you wiped down.I paint cars so trust me when I say the thinner wont hurt the paint.
P.S. If the vehicle has been recently painted I do not sujest to use the thinner.
Old Dec 3, 1999 | 08:13 AM
Troy Kislak
Guest
Posts: n/a
NEED HELP!
