Cold Start Problems ?
Old Dec 1, 1999 | 06:42 PM
Don's Avatar
Don
Hi guys. I have a 93 F350 5.8 FI , auto. Replaced the fuel filter and in tank pump also the fuel pressure reg. just did a tune cap, rotor, plugs, wires. I put in a can of dri-gas and changed the coolant temp sensor. And after all this the truck will still not start when it is freezing cold. I cant figure it out. Had it hooked up to a scanner and it came back fine. The engine just turns over and over, till the battery finally went dead and that was replaced also. I was wondering if the timing chain being worn would effect this. the truck has 95,000 mi. any input would be greatly appreciated
Old Dec 3, 1999 | 12:39 PM
PAUL_2's Avatar
PAUL_2
Hi Don ,
Check all the obvious things first ...Do you have fuel pressure at the engine , Do you have spark ? Why did you R&R all those things ? Check to make sure all the connections you disconnected got hooked back up
Old Dec 3, 1999 | 02:46 PM
slik's Avatar
slik
