Smoke Stacks
Old Jun 9, 2005 | 09:28 PM
greybullit's Avatar
greybullit
Smoke Stacks
Alright, so I found these 3" smoke stacks from JC Whitney. I am wondering if anybody knows if they will work on a 360 gas motor not diesle? Will they affect the performance or anything like that? They would look BAD so please let me know! Thanks
Old Jun 9, 2005 | 09:31 PM
brown79's Avatar
brown79
an associate of mine had a 1979 f250 4x4 with 5" stacks the stock single exhaust split into the two stacks performance did not suffer
Profanity removed by FTE
Old Jun 10, 2005 | 10:04 AM
Mike G's Avatar
Mike G
Those stacks are sort of "old school", had some on my 57 F100 20 years ago... They can be used on your gas motor with no problem, actually the 360 likes a little better flowing exhaust.
--Mike
Old Jun 10, 2005 | 10:32 AM
Purely Ford's Avatar
Purely Ford
Are you planning to use rain caps.
Old Jun 10, 2005 | 02:01 PM
greybullit's Avatar
greybullit
Did your associate get those made or buy the 5" stacks?
I don't think I will use the rain caps becuase they are angled out so I don't think rain should be a problem...
Old Jun 10, 2005 | 04:23 PM
jstandle's Avatar
jstandle
Dodge's Little Red Express had them from the factory back in the 70's.
They're getting real popular around my area with diesel pickups running flatbeds. I think on the right rig they look cool but if the rest of the rig isn't mimicking a semi-truck they look cheesie.
Old Jun 10, 2005 | 04:48 PM
cigarxtc's Avatar
cigarxtc
Ya, on the big tough looking trucks and diesel trucks it really makes them look beefier. It makes me think of the big rig trucks when I see the regular pickups with them installed. The only questions I would have is how much bed material must be removed for the holes? and do the external chrome pipes get too hot to touch? (There should be an internal exhuast pipe and an external chrome dress pipe, right?)
Old Jun 16, 2005 | 07:28 PM
brown79's Avatar
brown79
the 5 " stacks came off of a kenworth
Old Jun 16, 2005 | 07:35 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader
yeah Ron your right, there should be an inner pipe, and an outer heat shield/ chrome stuff...im planning on using 4" stacks for my snorkle exhaust on my 78 F-250 4x4, im even gonna run an air stack/snorkle beside one exhaust stack just like the big rigs......i would suggest a rain flap and a drain plug because water will find its way in there for sure.....
Old Jun 16, 2005 | 08:16 PM
HighProCam's Avatar
HighProCam
Post up some pics.
Old Jun 17, 2005 | 01:51 AM
Purely Ford
Like SwOkcOffRoader said, rain can get into the pipe. The big rigs will spew out quite a bit of moisture after setting through a rain storm if one of the pipes is pointing into the wind. I see the lower pipes that turn the exhaust up rust through quite often on the big rigs.
Old Jun 17, 2005 | 02:29 PM
SwOkcOffRoader
exactly.......way back when, my step father had an old KW and he installed radiator style drain pet***** in the lower part of the exhaust elbow, that way he could open them if there was any chance of heavy rain....
ascheperle
Aug 7, 2013 06:09 PM
hermancm
May 1, 2012 07:52 PM
ungerp
Oct 23, 2011 05:07 PM
ncinirator
Aftermarket Products
Nov 18, 2007 10:37 PM
nitrous125
Mar 14, 2002 12:42 PM
