Bronco II Ford Bronco II
Name that component
Old Jun 9, 2005 | 06:03 PM
BumpinB2's Avatar
BumpinB2
Name that component
Anybody know what the electrical component is that is located on the block just in front of the engine mounts (towards the radiator)? You have to look up from underneath to see it. It has one wire coming off of it and if you pull the wire off, it is threaded. If need be, I can get a picture of it, but if you look, it should be quite obvious. Could coolant leak around it? I have a leak and can't seem to pinpoint the location. I have ruled out freeze plugs and water pump/gasket. It seems to be coming from that "thing" or somewhere very near it. Any ideas are appreciated. Thanks.
Old Jun 9, 2005 | 06:10 PM
Help I M Stuck's Avatar
Help I M Stuck
if it's on the drivers side behind/below the steering pump and it's bell shaped then it's the oil pressure sending unit.
Old Jun 10, 2005 | 10:32 AM
80`F-150's Avatar
80`F-150
I know on the front of th V8`s (around the sme place your discribing) theres a theres a nother temp. sendiong unit.
Old Jun 11, 2005 | 07:29 PM
BumpinB2's Avatar
BumpinB2
Thanks for the replies. Guess I'll have to keep looking for the source of the leak.
