87 carbureated 351 emissions problem
Old Jun 9, 2005 | 03:35 PM
lksouth's Avatar
lksouth
Although I've tried to search for specifics, I am unable to figure out the search function. I am failing the emissions test in NC. HC PPM reading is 411 and should be 220 max. CO% is 5.55 and should be 1.2 max. Truck has new carb, plugs, wires, roter/cap, and PCV valve. Truck starts and runs fine. I haven't a clue where to start. If this has been addressed somewhere on this site, I am at a loss to find it. All my searches produce over 400 targets, most of which have nothing to do with my search parameters.
Old Jun 9, 2005 | 05:33 PM
Popa Tim's Avatar
Popa Tim
Has the carb been adjusted? Most new carbs come set rather rich if I recollect correctly.
How old is the Cat?
Old Jun 9, 2005 | 05:46 PM
lksouth's Avatar
lksouth
I recently bought the truck and didn't install the carb myself so not sure of mixture adjustment. However, I have verified idle speed, fast idle speed, timing etc. I just noticed that the vacumn to the air bypass valve has been capped off, which could be the problem. I'm thinking that the air pump isn't getting air to the cat. Cat appears to be original equip. As soon as I can figure out the proper vacumn hook-up to the air pump bypass valve and make sure it's hooked up properly, I'll get back to you. Thanks a lot for the response.
Old Jun 14, 2005 | 10:14 AM
lksouth's Avatar
lksouth
Got it fixed. Studied the vacuum diagram under the hood for 3 days and finally found a cracked vacuum line that was causing the cat to be COMPLETELY BYPASSED. Upon repair, the HC (ppm) went from 411 to 52 and the CO% from 5.55 to .21. And who said that cats don't reduce emissions???????????
Old Jun 14, 2005 | 10:18 AM
MustangGT221's Avatar
MustangGT221
Nice job, glad to hear you found the problem...
Couldn't of been that bad on a carbed model Gotta love em'.
drh1175
2009 - 2014 F150
17
Jul 12, 2024 12:48 AM
kkcc16
Dec 17, 2016 05:30 PM
FordBequeather
15
Oct 17, 2015 03:50 AM
cclaeys
Mar 5, 2015 10:20 PM
burbur23
Nov 16, 2005 07:29 PM
