get AC installed or use a portable
Old Jun 9, 2005 | 01:25 PM
corpsedub's Avatar
corpsedub
my F-150 is a custom with no air and that cab sure does get hot in the sun. im trying to go the lowest $ route for releif. i have looked on the net but i cant find a reasonabley priced portable air unit that would fit in a car. i have seen some swamp cooler type devices but those are usually over 300$. what about those old swmp coolers people used to put on thier windows that would force air into a tube and into the car. anyone know where i can pick one of those up? or should i bit the bullet and find someone to install factory air?
Old Jun 9, 2005 | 03:19 PM
Steina's Avatar
Steina
CO River Rat
Where in CA do you live? If it's the desert, you MIGHT be able to mickey-mouse an evap cooler to work. The old tube-style had several drawbacks; you had to be moving for it to work, it didn't hold much water and you had to pull on a cord to keep the pad moist.
One of my boating catalogs has a 12V device that fits in a cooler full of ice and blows out cool air; if you're interested I'll get you the info.
Steve
Old Jun 10, 2005 | 02:46 PM
hhott71's Avatar
hhott71
thier 300$ would be wasted
not knowing the year of your f150 its tough to price a system.
for all NEW parts an underdash kit could be had for $700 on up
Old Jun 11, 2005 | 08:51 AM
RockWVU's Avatar
RockWVU
hhott71, Could you give me some info on the kit you are talking about?
I have a 1980f150
Old Jun 12, 2005 | 10:48 AM
corpsedub's Avatar
corpsedub
thanks for the replies. i have looked at the evap coolers like the ones here:
http://www.swampy.net/
im in the bayarea/norcal so the humidity is around 45% or so. dont know if those evap coolers would be more troubble than just getting real A/C installed. the truck is a 92(see sig)
Old Jun 12, 2005 | 11:32 AM
Steina's Avatar
Steina
CO River Rat
Looks like the ones that use chilled water from an ice chest would work pretty well, if you have the room and 20# of ice/hour wouldn't be a problem; 45% humidity is too high for an evap cooler to work.
Steve
