Replace or Rebuild?
Old Jun 9, 2005 | 10:22 AM
hallardclan's Avatar
hallardclan
Replace or Rebuild?
I have a 66 Ford Truck and want to know what is the stock engine that comes with the truck? It has a 390 in it already. It needs to be replaced should we go with another 390 or a 302 AOD? Which would be a better performer or workhorse?
Old Jun 9, 2005 | 11:11 AM
oldfords4ever's Avatar
oldfords4ever
You will be better off going with the 390 if you want a workhorse of a truck.
Old Jun 9, 2005 | 11:28 AM
hallardclan
That's what I thought.
Old Jun 9, 2005 | 02:51 PM
Mike G's Avatar
Mike G
Came with the 352FE if you have a VIN of F10D, looks just like your 390.... The 390 won't need a new tranny and won't be overworked by the truck.
--Mike
Old Jun 9, 2005 | 03:06 PM
66beater's Avatar
66beater
390's an FE block. It can make as much horsepower as the 302, but WAY more torque, and at realy Low RPM. My 3 speed will pull from a stoplight in top gear, and it's a stock motor. The 302 is a great motor, but it's not a big block, and it's not built to do the things an FE block will do.
Old Jun 10, 2005 | 03:50 PM
pootscratch89's Avatar
pootscratch89
I have a 390 in my 57 and really enjoy the power. However, I do not enjoy the gas mileage. I sometimes wish I had a 302. The only other problem I have with the FE is parts seem to be a little more expensive, and not nearly as accessible as a small block. But like I said, I do enjoy the power when I have to pull a heavy load!
Vernon
Old Jun 10, 2005 | 05:04 PM
MR Harley's Avatar
MR Harley
Stick with the 390 you'll be happier in the end.
