Tire size question?
Old Jun 9, 2005 | 10:18 AM
MBBFord's Avatar
MBBFord
Question Tire size question?
I want to put the biggest tire I can under a stock suspension set up.
What size could I get away with, with some tire rub? I would like to fit 33s, is this possible.
With out tire rub, could I get 32s? Or would I have to go lower than that?
Thanks for any help,
Matt
Old Jun 9, 2005 | 10:24 AM
ChrisAdams's Avatar
ChrisAdams
Matt
Um, on what kind of truck? I see a Bronco in your profile...
Since you are asking in the 04-05 forum, I'm gonna guess you are interested in some kind of F-150 04-05.
They come stock with 30 and 32 inch tires. The four wheels have 32 stock. The two wheels have 30. Ford uses about 9 different stock sizes, and they range from 29 and change to 32 and change. So they will fit. Lots of guys have 33 inch on their trucks, no mods. Of course, the bigger the diameter of the tire, the more you raise the already high gearing.
Chris
Old Jun 9, 2005 | 10:35 AM
MBBFord's Avatar
MBBFord
Thanks Chris,
I'm trying to help out my uncle on this he has a 04 F-150 Fx4. Sorry I didn't really mention that.
So 33in. tires will fit, do I need that front end leveling kit or no?
Thanks for any info,
Matt
Old Jun 9, 2005 | 10:43 AM
Ruckus's Avatar
Ruckus
MBB, Are you or your uncle running 17 or 18 inch rims?
Old Jun 9, 2005 | 10:53 AM
MBBFord's Avatar
MBBFord
My uncle has 18s and He hates the cost of mud tires with 18in. rims. I really likes the idea that mud tires for 15in rims are cheap. I have 15s. He wants a set of rims and tires, for hunting season, and keep his 18s on there all other times, because he doesn't want to wear his grips out just going back and forth to work.
He doesn't have a name for this forum, and he doesn't really have the time to do all this stuff, so he asked if I could help him out.
I was wondering if he could at least get away with 16.5 in. rims, IS this possible???
Matt
Old Jun 9, 2005 | 11:05 AM
ChrisAdams's Avatar
ChrisAdams
The 04 type trucks do NOT use any rim smaller than 17.
No can do.
Sorry.
Chris
Old Jun 9, 2005 | 12:16 PM
Ruckus's Avatar
Ruckus
Smile
MBB,I thought you wanted larger tires.I am a little confused about what you really want.Do you want them just for hunting season or hunting and fishing combined?
Old Jun 9, 2005 | 12:36 PM
MBBFord's Avatar
MBBFord
I want the biggest tire I can fit under a stock Fx4 for Hunting season. I will get a set of rims and tires just for that. For every day driveing I want to use the all terrain already on there, and just swap sets during hunting season.
It is mostly to put grip tires on a smaller rim to bring down the cost of a grip tire compared to running them on 18 in. rims all the time.
Matt
Old Jun 9, 2005 | 12:47 PM
Ruckus's Avatar
Ruckus
MBB, You cannot go smaller than 17 inch for hunting season.The 17 inch rim is the smallest Ford makes for the new body style 04 F150.You could probably get a real small, cheap skinny grip tire for hunting season.It might look a little odd with a little skinny grip tire on a big nice FX4 truck.Good Luck!
Old Jun 9, 2005 | 01:00 PM
MBBFord's Avatar
MBBFord
I was just hoping at least a 16.5 inch rim would fit but thanks any way. I'll end up going with a cheap 17in. rim and have to get some super swampers (trxus mt).
Thanks for the help guys,
Matt
Old Jun 9, 2005 | 01:23 PM
Ruckus's Avatar
Ruckus
Smile
Matt
What about the 33's you wanted?What size tire do you have now?
Old Jun 9, 2005 | 01:50 PM
jamesa30's Avatar
jamesa30
I have a 2005 F150 4x4 and I put LT295/70 R17 (33.19" x 12.13" x 17") with a 17x8 wheel and have not had any rubbing lock to lock. I will be taking it offroad next week to see if it rubs under more agressive driving.
By the way, my suspension is stock.
Old Jun 9, 2005 | 11:12 PM
MBBFord's Avatar
MBBFord
Ruckus I have 275 65 R18 which I think are 32s. I still want the 33s on a set of 17in. rims to swap in for hunting season, but out side of hunting season, I'll use the stock 32s.
Old Jun 9, 2005 | 11:13 PM
MBBFord's Avatar
MBBFord
Oh thanks for the info Jamesa30, and everyone else, I'll be getting a set up like mentioned in privious post, but I have to wait for the money to come in.
Thanks again,
Matt
Old Jun 10, 2005 | 03:22 PM
YOMAN's Avatar
YOMAN
Just want to a bit clear that 275/65/18 is actual 31.5" ( you can try measure your tire )
Myself dislike 18" (big rims with small rubber yikes!) but it came with my truck..i will downgrade to 17 when i have $$ .
The reason that you can not go smaller than 17" is cuz of brake caplier is bigger, thats why.
BFG ATKO, Nitto AT, toyo AT are good tires!
YOMAN!
