Brighter Tail Lights!
Old Jun 10, 2005 | 05:12 PM
AXracer's Avatar
AXracer
Cree only sells in volume to major manufacturers. There are a number of suppliers (check the ads in Street Rodder magazine) That have boards to fit a number of popular taillights, "universal" array boards of many different sizes and configurations and will make custom arrays. They have some 3rd brake light and strip taillite arrays that can have the functions programmed in and way you want, with thick acrylic lenses so you can flush mount them and sand them to match the panel contour. They are bright enough they claim that you can shoot a coat of color over them so they disappear until they light up and show right thru the paint!
Old Jun 10, 2005 | 06:17 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I was thinking about grafting a light bar (stoplight) display on the top, inside of my rear window, and feed it thru the headliner, so I won't have any drilling/cutting to do.
Old Jun 10, 2005 | 06:31 PM
AXracer's Avatar
AXracer
There is a unit like that made that mounts similar to and resembles a long thin rearview mirror but in the back window.
Old Jun 10, 2005 | 10:33 PM
fatfords's Avatar
fatfords
I'll have to check what's available retail. I haven't checked for a year or so. I've got half of a '68 Firebird tail light frenched into either side of my roll pan. There are two red sections, ~1" X 4.5" and a clear section in the middle for B/U lights. I would like to go with LED's because the enclosure is very small and I'm afraid it will overheat and damage the lense, or catch the whole thing on fire!
Thanks for the suggestion.
Old Jun 11, 2005 | 10:32 AM
AXracer's Avatar
AXracer
Dewayne, Albuq try www.lambertenterprises.com
for custom arrays and pedestal mount 3rd brake lites.
www.hotronicsproducts.com lists no load plug in replacement flashers for LEDs.
Old Jun 11, 2005 | 02:34 PM
ALBUQ F-1's Avatar
ALBUQ F-1
It occured to me yesterday that I should put amber LED's in my front turn signals; the '51 - '52 fronts are a real PITA, and they are off and apart at the moment. I have been unable to find any that will fit and are "dual filament" (1157 or 357) except in Red. 1157 is a brake light bulb so I'm not surprised.
AX -- tghanks for the link, I'll give them a shot.
Old Jun 13, 2005 | 11:34 PM
AXracer's Avatar
AXracer
go to www.yearwood.com and search on led 1157.
They carry direct 1157 replacement LED arrays in red: bright, super bright, and ultra bright; as well as amber in bright and super bright! @ $8, 10, and 15.00 each respectively they are easily affordable as well. I'm ordering a pair for the trailer tomorrow!
Old Jun 14, 2005 | 08:47 AM
ALBUQ F-1's Avatar
ALBUQ F-1
How do you delete a post if you screw up?!?
Old Jun 14, 2005 | 09:01 AM
ALBUQ F-1's Avatar
ALBUQ F-1
"tghanks" again AX, there is a Yearwood here in town (not sure it's the same outfit), will check it out!
Old Jun 14, 2005 | 09:43 AM
Earl's Avatar
Earl
You can edit it within an hour and change the text to read something like "Post error - deleted". The other option is to ask the forum moderator to remove it, but unless it's a major boo boo, it's usually not worth the effort to have it removed as it might take a while.
Old Jun 14, 2005 | 10:03 AM
f1fordguy's Avatar
f1fordguy
I used white LED dual element on both the front and rear stock tail lights and running/turn signals. I lighted them up and they were plenty bright. I wouldn't use halogen as they get way too hot. Actually saw a $300 tail light lenses on an Acura melted from them.
I could have sworn that I read somewhere that colored bulbs were illegal. That the color was supposed to come from the lens. I know that I have seen colored bulbs marked on the package "for off road use only". Don't recall if that was halogen or LED though.
Perhaps this is all just a verbalization of a "senior moment".
Tim
Old Jun 14, 2005 | 12:32 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I believe that is true (about colored bulbs), same section of the law that makes blue dots illegal. Cops have better things to do than enforce it.
Old Jun 14, 2005 | 01:16 PM
  #28
f1fordguy's Avatar
f1fordguy
"Cops have better things to do than enforce it."
Not down here! Unfortunatley, law enforcement seems to be all about money down here.
Old Jun 14, 2005 | 01:32 PM
  #29
AXracer's Avatar
AXracer
Have to see if your state's DOT has different laws than fed guidelines, but fed say all forward facing lights must be white or amber, rearward facing lights must be red or amber. I don't think they differentiate between the bulb color or the lens color. I really doubt any cop is going to make you pull out your taillight bulb to see if they are white or red.
I realized this AM I can't use the replacement led array in my trailer the bulb socket faces sideways instead of towards the rear.
Old Jun 14, 2005 | 05:13 PM
  #30
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
I recently scrounged a really cool set of tail light housings from a late 40's chrysler that I think I will adapt to my F1. The lenses are glass and rather thick so I bet that a stock bulb would be a bit dim. I think that these LEDs might be just the ticket when the time comes.
As AlbuqF1 can attest to, New Mexico drivers are not exactly the cream of the crop. I probably see 3 -5 rearend accidents a week in this town
Jag Red 54
N. California Chapter
Sep 4, 2013 11:04 AM
SocialDistortionFan
Jul 9, 2013 11:25 AM
SocialDistortionFan
May 14, 2013 08:18 PM
abe
Feb 23, 2013 02:58 PM
ken selvy
Oct 2, 2009 02:36 PM
