400 ford cam question
Old Jun 8, 2005 | 06:39 PM
79_f150's Avatar
79_f150
I just bought a 79 f150 with a 400 and c6. Other than it having a burned valve it runs like a champ. After the heads get redone, I will be in the market for new cam. I would like it to give my motor a bit of a gallop at an idle. (about 800rpm). Since it is an automatic I dont want to have to raise the idle too far past 800rpm, so I dont want the cam to be too lopey. Does anyone here know of a cam they would suggest to get this idle? Any suggestions would be greatly appriciated. Thanks
-Mike
Old Jun 8, 2005 | 08:43 PM
tastyklair's Avatar
tastyklair
I use the Crane 941. It is a noticable idle but not real lumpy. I can get it to idle at 600 in gear with a stock converter. You need to have at least 8.75 cr for it and probably for most any other cam that would get lopey on you.
Old Jun 8, 2005 | 09:00 PM
grclark351's Avatar
grclark351
comp cams 268H will lope real nice prolly down to about 500rpm if you want it to. the slower you set it the cooler it sounds.
Old Jun 9, 2005 | 09:22 PM
beeboy's Avatar
beeboy
https://www.ford-trucks.com/forums/s...5&pagenumber=1
