Hi my truck is a 1988 f150 supercab 351w auto anyway today i was out and left my AC on when i shut off my truck got back in the truck mabe 10-15 mins later No AC so i turned the AC off ...Made yet one more stop for mabe 10-15 mins.. then when i got going again i tryed the AC now its working again.. something is not right but what?????????
Thanks for any help with this......
James
what was the outside air temp like when this happened, and was the AC working well, or do you have to run at high fan constantly to get a little bit of relief?
I had that problem a while back and could not figure it out for the life of me. I found out that sometimes I have to wiggle the key forward to make it click on. If it happens again try and wiggle the key and see what happens.
Are you saying that when the AC "wasn't working" do you mean that there was absolutely no fan action or it was blowing warm?
I wonder if you have replaced the compressor or ever had a major leak/failure and had the system apart? There may be contamination in the system and the orifice tube is clogging up. Reworked or retrofitted AC systems need a very good flush after a major failure and precautions should be taken to keep dirt out of the lines.
One especially nasty contaminant would be water, this causes problems like yours also. Is the system R12 or 134a refrigerant?
Hi, yes when i said it was not working i mean No fan no air of any kind.. i have only had the truck for a short time since i have had it i got the AC recharged so now when it does work it blows good and cold.. i have not had any thing eles done with the AC system but i do not know if the former owner may have done something or not..I got the truck from a small car lot the guy told me he had to reposee it ... when i pruchased it only things i have had to do was replace the start key cyclinder lock the door locks got an oil change and had the AC Recharged...
James
