Sponsored by: Real Truck
Another Tire question ?
Old Jun 8, 2005 | 03:56 PM
Winberry Farms's Avatar
Winberry Farms
I just purchased a very clean 2001 V-10 F-250 crew cab. I am new to Fords and I was wondering with out lifting what is the biggest tire size I could get comfortably on this truck without a lift. It currently has the factory steeltechs by Firestone on it. The truck looks so puney with such a smalll tire. I want to keep same rims and just put a bigger non rubbing AT tire on her. CAn yoyu guys help.
Yes this is my first ever post and thanks fot all your great info.
Thanks
Winberry Farms
Old Jun 8, 2005 | 04:17 PM
Autobahn F-250 Lariat's Avatar
Talking
You can go with a 295 bfg a/t some have even gone with 305's it all depends on the brand as all tires are not created equally
below is a pick of Munkey's truck with 295 bfg's
https://www.ford-trucks.com/user_gal...oid=38247&.jpg
Old Jun 9, 2005 | 06:21 AM
Winberry Farms
Thanks for the help, Thats the tire I had in mind anyway.
Old Jun 9, 2005 | 02:13 PM
Fords4Me's Avatar
Fords4Me
Will the 295's and 305's work with the stock width rims?
Old Jun 9, 2005 | 08:41 PM
utahtom's Avatar
utahtom
Winberry,
It sounds like your situation is similar to mine- Stock rims and want a bigger tire. I tow heavier loads and am concerned about running 285/75/16 (vs stock 265) due to the 7 inch stock rims. IMO if you are not towing heavy loads, the 285's are fine. I run a studded & siped snow tire in the winter with no issues... but I don't tow heavy loads during the winter.
If you want taller, 255/85/16 will fit on the stock rims but have a slightly lower weight rating (3,000 lbs). At this time, I am relatively convinced that the 285/75/16 is as big as you can install on stock 7 inch rims and the tire pressure should be kept up near the maximum pressure rating, especially when towing. JMO
