Sponsored by: Kumho
No front brakes please help
Old Jun 8, 2005 | 08:10 AM
HICKEY's Avatar
HICKEY
I have a '75 f250 that had drums all the way around. I put an '86 f350 front axle under it with disk brakes. After making the swap i no longer have front brakes. i have replaced the calipers master cylinder added a 10 psi res valve on the rear and a 2 psi on the front. after adjusting the booster push rod all the way out i finally got a pedal but i have no front brakes at all. any suggestions.
