Modular V10 (6.8l)
Gauge Accuracy
Old Jun 8, 2005 | 12:23 AM
Danoco's Avatar
Danoco
Gauge Accuracy
Anyone know if the ford SD oil and temp gauges hold any accuracy or is halfway between high and low just "working"?
Old Jun 8, 2005 | 04:45 AM
captchas's Avatar
captchas
Guest
about the same with mine. if it's not in the red it's normal.
Old Jun 8, 2005 | 07:36 AM
Ultraute's Avatar
Ultraute
The oil pressure "gauge" is nothing more than a glorified idiot light. The sending unit is a simple on/off unit, that is set to "normal operating range". (close @ around 10? PSI) The "gauge" only tells you if it's "in range" or not. If/when not in range, the check engin light should come on.
The engin coolant gauge is variable, and should give you an indication of current temp.
Atleast that's how they work on my '03 E-350 V-10.
Old Jun 8, 2005 | 10:32 AM
Danoco's Avatar
Danoco
Thanks for the replies.
