Clutch problem?
Old Dec 13, 1999 | 02:10 AM
jason's Avatar
jason
Clutch problem?
Old Dec 14, 1999 | 07:48 PM
Roy Chris
Guest
Posts: n/a
Clutch problem?
I have a 94 f150 with a 300/6 and a mazda 5 speed with 100k on the ticker and quite often when parking and going from 1st to reverse or visa versa it doesnt want to go into gear sometimes its even hard to pull out of gear, if I shut the engine down it slides right in --any ideas?
Old Dec 15, 1999 | 09:17 AM
Phillip Guidry's Avatar
Phillip Guidry
Clutch problem?
First,check the fluid level in the clutch master. If you find you are low, add fluid but there is a reason for the low fluid as in either a leak or evaperation.If fluid is good,you may try having the system bled properly. I think there is a tech article here on the main page that helps with this.
Phillip
