I-Beams
Old Jun 7, 2005 | 11:51 AM
bigblock78's Avatar
bigblock78
I-Beams
I have a 78 2wd F-150 and I bought DJM's 3'' dream beam lowering kit with poly bushings and tie rod relocators and new king pins. Then I seperately bought poly radius arm bushings for a 78. Now I recently found that the frame is a 1974 and apparently there are differences between up to 1974 and 1975+ Front suspension set ups. I know I need new radius arm bushings but will my I beams still work cause it looks like they will? Please Help!!!
Old Jun 7, 2005 | 12:47 PM
quehele's Avatar
quehele
You're Ok...
I'm about to RAISE my '77 and the company I'm buying the re-curved I-beams from sell the same ones for '65 through '79.
Best of luck.
Jim
Old Jun 7, 2005 | 01:32 PM
bigblock78's Avatar
bigblock78
I went and looked at them again and I am sure they will work. I think the differences are, at least from what I can dig up, are the touque specs. thanx for your help
Old Jun 8, 2005 | 05:20 AM
SRD4X4's Avatar
SRD4X4
The kingpins are different,66-74 are the same,75-79 are the same.Your going to have to find spindles/knuckles from a 75-79 to use with the new I-beams.
