heater core.
Old Jun 7, 2005 | 11:19 AM
Redneck'n's Avatar
Redneck'n
heater core.
truck: '79 f-250/460/c-6
problem: heater core started leaking water yesterday on my way home.
what i did: for now, i routed the hoses into each other. taking the heater core out of the picture all together. this is a temporary fix.
question: is this going to hurt anything to run it like this for a month or 2?
I live in an apartment here so i dont really have a good place to work. yet.
Old Jun 7, 2005 | 11:40 AM
Torque1st's Avatar
Torque1st
Posting Legend
It will not hurt anything. Good luck on replacing that core.
Old Jun 7, 2005 | 11:46 AM
fred_79f250's Avatar
fred_79f250
When you get around to replacing it - - -
There is a bolt just under the dash on the passenger side that bolts the dash to the cab wall. I found that removing just that one bolt gave enough play to the dash to make getting the heater body assembly much much easier.
Old Jun 7, 2005 | 11:59 AM
Redneck'n's Avatar
Redneck'n
glad to know it wont hurt anything..
i was thinking on the old f-350 back home that it was tied off because dad didnt want to mess with changing it. i just wasnt sure if i was remembering correctly or not.
i will keep the bolt inside in mind when i do get around to messing with it.
I had a friend change his in an 84 f-150 and he said it is a pain in the **** to do. but, he is also the same fella that took 2 full days to replace the upper head gaskets on my chebby.
so i figure it is just him.. we'll see in a few months.
Old Jun 7, 2005 | 12:15 PM
FalconStng's Avatar
FalconStng
changing the heater core is a pain...not impossible though. Here in TX, if mine goes out I'll bypass it and probably never fix it...I would fix it if I needed a heater.
Old Jun 7, 2005 | 12:25 PM
fellro86's Avatar
fellro86
on my 75, it had aftermarket air, the complete dash had to be removed, so yes, it is a pain in the behind, but doable.
