? on pistons
Old Jun 6, 2005 | 08:12 PM
kevinupchurch's Avatar
kevinupchurch
? on pistons
which pistons would give me more compression the 22cc w/compression distance of 1.772 or 21cc w/1.760.thanks kevin
Old Jun 7, 2005 | 09:22 AM
garsten's Avatar
garsten
according to my calculations with a stock 460 bore of 4.36 in., the increase in compression ht. decreases the swept volume by 2.93 cc's. the 22cc piston will give you more compression. the deck ht. of your block will dictate which piston you should use. the reason you see 460 pistons with different comp ht.'s is because the deck height increased by approx 0.02 inches in the early 70's. cheers, garsten
