I want to replace a 302 with a 351W in my '94 F-150. I cant find a consistant list of parts that I need to do the job. If anyone can help I would appreciate it.
Nick34 you been moved, I would ask the same question in the forum titled "performance, engines, and troubleshooting" Then scroll down to the section for 221, 260, 289, 302 351w V8's.
I hope you find this post, in the future, keep your questions in the appropriate forums. If you want to ask about oil, go to the oils and lubrication section. If you have a question about a 351w head than ask that question in the 351w section.
well how complete of a 5.8 do you have? the swap is really easy. you just reuse your 302 wiring harness , motor mounts and accesory brackets all fit the 5.8. you will need to correct flexplate for a 5.8/ tranny combo your running. also the upper/lower intake for a 5.8. you will also need to get your Y pipe widend just a little.
This is a great swap/mod you will be real happy. ive had mine like this for 2yrs now and have zero issues. even get better mpg
