Sponsored by: Auxito
5.4 Engine Knocking
Old Jun 6, 2005 | 02:31 PM
chargedstang89's Avatar
chargedstang89
5.4 Engine Knocking
Hi all. My buddy has a 1998 f-150 4x4 with the 5.4 in it. After a trip pulling his boat, he started it up for the first time a couple of days ago and the engine is knocking. I listened to it, and I can't tell if it sounds like a bent valve, or a rod knock. With the engine shoved so far back in the truck, it's hard to isolate the sound. Is there any way I can determine whether it is a rod or valve, or piston slap without having to take it to a shop? I unplugged the coils on each cylinder on the passenger side and the sound did not change. It also sounds like it is indeed coming from the passenger side, but again...the noise is hard to isolate. I know I could also do a compression test on each cylinder to see if any of the valves or pistons are bad. But, is there anything else I can do to determine what the problem is, or is there a known issue with these engines?
Old Jun 7, 2005 | 12:13 AM
Racerguy's Avatar
Racerguy
Is the noise there after the engine warms up too?
Old Jun 7, 2005 | 08:32 AM
chargedstang89
yes. it is there after the engine is warm, and stays constant with rpm's as you rev it too.
alloro
Mar 10, 2017 02:51 AM
John12341234
1983 - 2012 Ranger & B-Series
Mar 30, 2013 09:34 AM
FoxNotch
Modular V8 (4.6L, 5.4L)
Dec 29, 2011 12:23 PM
AbandonedBronco
20
Dec 30, 2010 11:07 AM
Strouss
Modular V10 (6.8l)
Nov 1, 2009 01:02 AM
