Electrical? Won't run...HELP
Old Jun 8, 2005 | 06:56 PM
dogman's Avatar
dogman
chuck L. undo the wire to the alternator and huck the battery back up see if you have a heavy arcing, if so undo the wire at the starter and see if you have a heavy arcing there, the starter could be bad it may ckick out and still be bad.
