Sponsored by: Auxito
front end squeak
Old Jun 6, 2005 | 12:09 PM
gman150's Avatar
gman150
front end squeak
hello, i have a 1998 F150, and over the past couple of weeks i have noticed that the front end is sqeaking, when i corner. i was wondering if the front end just needs to be greased, becasue when i bought the truck the front end was pretty dried out. I changed the ball joints in the truck before the winter, and new front rotors and pads.
thanks for your input,
garrett
Old Jun 6, 2005 | 10:56 PM
blazerf250's Avatar
blazerf250
My 97 f250ld squeaked real bad. There's only a couple places to grease it. What helped me was I grabbed a can of wd40 and sprayed all of the joints and rubber deals and it doesn't make any noise at all now! Worked for me!
Old Jun 8, 2005 | 06:32 PM
blacksheep-1's Avatar
blacksheep-1
These trucks are kind of known for that, find some WD40, or more prefferably some moly type spray lube and have a buddy turn the wheels back and forth with the truck jacked up. Hose down everything that is coverred by a rubber boot. That should stop it.
