3.55 to 3.73 rear end change
Originally Posted by flyguy2
I'm not planing to change the tires. I have Yokahama Geolanders on the truck. I think there 17" but off the top of my head I'm not 100% sure.
Also increasing gear size will help out in lower rpm's and taking off it will also eat more gas. Unless u are are increasing ur tire size and lifting it is an inordinate cost and not economical. If u switched down and replaced your gears with higher gears in the 2 range ur fuel economy would increase and your pulling power, these gear sets are often refered to as highway gears.
Originally Posted by AAALeadFoot
Your rims are 17" not your tires....right??
Originally Posted by captain p4
The swap from a 3.55 to a 3.73 doesn't seem like enough of a difference for the money for me. I would at least go to the 4.10.
Berto, "on paper" if you lift your truck or add bigger tires or both, then lower your gears ie. 3:55 to 4:56 you will gain back your lost power and mileage, again on paper. In reality if you do this you will gain some of it back but not all of it. You still have more rolling resistance from the bigger tires and more drag from a taller truck. I guess to sum it up... sorry I rambled from your question a bit... generally speaking A numericly higher gear will give you more power/ less mileage while a numericly lower gear will give you less power/ more mileage. Remember there are always exceptions to any rule, this is just a generalization.
#28
#29
Berto, your tires have a diameter of 32.8 inches. It would help to know a little more about your truck but I'm guessing you have 3.55's also what stock tire size you have. A good rule of thumb is one tenth on the ring gear for every inch in tire change. If you had 30" tires to start with and now have 33" tires you would add 3 tenths to your ring gear ie. 3.55 to 3.85 ther are no 3.85's so you can go up to a 4.10 (what i would do)
to help compensate for more width and lift height, plus it will make it a lot more fun between red lights. If you go with a 3.73 your still gonna be a bit sluggish, and as mentioned before 3.55 to 3.73 isint really worth the trouble. If you do a search on this site you will shurely find a lot of links to tire size calculators and ring gear to tire size calculators. Sorry this is so long, and I hope it helps you.
David
David
