code 22 ?
Old Jun 5, 2005 | 09:30 PM
Pigeon's Avatar
Pigeon
code 22 ?
sometimes when i scan my truck in koeo mode it will produce a code 22 "manifold absolute pressure or baro sensor out of range", but not all the time. Does anyone know what that is and why it only happens about a third of the time?
Old Jun 6, 2005 | 01:24 AM
tdford's Avatar
tdford
Are you sure you wanted to post this question in the 7.3 IDI forum?
Old Jun 6, 2005 | 01:39 AM
PLC7.3's Avatar
PLC7.3
What altitude are you at. The code 22 states the BARO is out of onboard diagnostic range or it failed the dynamic response....(goose test).
Old Jun 6, 2005 | 08:30 PM
Pigeon's Avatar
Pigeon
elevation is around 1050 ft., what does BARO stand for?
Old Jun 6, 2005 | 10:13 PM
PLC7.3's Avatar
PLC7.3
Barometric Pressure Sensor .....on a gasser its a MAP .. Manifold air pressure. If you look on top the heater box there should be a black Item with 4 wires attached to a firewall bracket. All Fords of our vintage have them..........
The purpose oif the BARO is to change the shift schedule at higher altitudes so as not to burn up the trans because of lower power........
Old Jun 7, 2005 | 02:16 PM
TimMcGraw67's Avatar
TimMcGraw67
Gassers use a baro or a map... Sometimes both
