Can Someone please tell me at what speed the govenenr cuts in at on the 2004 FX4 Level II cause mne cuts out at 93 and that seems way to slow for me.
Power steering fluid leaking while i was doing donuts the other day added some more too and drove like 150 miles and none leaked out can someplease tel me is goin on with thiss thing
Rangers have a speed gov set at about 90-95mph, only way around it is to buy a chip with it removed.. about $300.00. my guess on power steering fluid was because it was turned to left or right lock and engine was over the rpm range.
Dave
Deff learned my leason on this one got home from North Carolina to find out that my rearend was leaking dealer told me that there was a bunch of grass wraped around the seal thank god he said that he would cover it this time under waranty.
There's a recent thread in here regarding the Torsen rear ends and the seals leaking. Although I haven't gotten bit and hope I never do, sometimes I really wished I had my 94 back. Rear end seals leaking at 15-50K miles is TOTALLY unacceptable in this day and age and I/we should NOT have to buy an extended warranty in anticipation of this and a few other things needing service down the road .
There is a vent on the rear end that allows the grease to expand when it warns up, if the vent gets plugged the grease will force itself out around the seals. That is my guess, glad you got it fixed.
Dave
