valve train problem
Old Jun 5, 2005 | 12:51 AM
ha2400's Avatar
ha2400
valve train problem
I was reveiwing the tech articles here https://www.ford-trucks.com/article/...le_Secret.html
And i'm wondering if aftermarket heads will avoid this problem of valve preload. Engine rebuilding is new to me especially valvetrain components.
Old Jun 5, 2005 | 07:54 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Aftermarket heads wont eliminate the problem ...but adjustable rockers will..So you can set each lifter to a certain preload regardless of push rod length's (within reason)
For instance you couldnt have 15 - 8" pushrods in there and then have one 7.750" long pushrod and expect the rocker to make up the differance...
Even if the adjuster would take up the slack..it would throw your valve train geometry off at the Valve tip...
Russ
Old Jun 5, 2005 | 08:36 PM
ha2400's Avatar
ha2400
so what would your referal be for adustable rockers any particular kind? Also can i use hydraulic flat tappet lifters in a FE?
Old Jun 6, 2005 | 07:36 AM
RapidRuss's Avatar
RapidRuss
Well depending on your build ?? and the Cam that you choose to run..as long as it doesnt have over say .550" lift..the Stock for adjustable's will work just fine..
and Yes a flat tappet Hydraulic Cam is what you'll want to go with...Unless the motor you have is one of the few Hi-Po Factory motor's that had a Mechanical cam...which is unlikely...but anything is possible??
Edit: also make sure to use the Cam Maker's Recommended Valve springs..
Russ
Old Jun 6, 2005 | 07:59 AM
ha2400's Avatar
ha2400
thanks that helps alot
Old Jun 6, 2005 | 08:00 AM
RapidRuss's Avatar
RapidRuss
No Problem...Enjoy your build....and keep us posted on your results!!!
Good Luck...
Russ
Old Jun 6, 2005 | 01:24 PM
rusty70f100's Avatar
rusty70f100
Hey, I'm running stock adjustables on my build, and I'm running a cam with .563" exhaust valve lift. Works great. Just had it up to 5000rpm's today (manually shifting). I think about .575" is the limit though.
fordboy_52
1983 - 2012 Ranger & B-Series
1046
Jun 25, 2023 04:16 PM
Fomoko1
Feb 10, 2014 05:07 PM
Fomoko1
40
Oct 25, 2010 11:28 AM
dethomson
Apr 2, 2009 11:50 PM
darkknight9
Jan 24, 2005 11:04 PM
