eratic idle!!
Old Jun 7, 2005 | 10:38 AM
jhforman's Avatar
jhforman
Originally Posted by ugotkern
Which rubber hose was it?
on the passenger valve cover there is a PCV valve that ran to the back of the intake !! its a complete PAIN to get to !! but if you trace the hard plastic line from the valve cover back it will run to a right angle rubber fitting on the back of the intake. this was dry rotted replaced it you have to remove the triton 5.4 cover to gain access to it !!
Old Jun 7, 2005 | 11:09 AM
ugotkern's Avatar
ugotkern
Thanks for the reply but I had already replaced that hose and still have the same issue
Old Mar 26, 2006 | 09:59 PM
ronm0660's Avatar
ronm0660
My 97 did the exact same thing took it to Autozone and got the same reading changed out all of the 02's didnt help. Check underneath the AIC there is a vacuum line that comes out of the manifold (its a rubber elbow) they go bad easily. The Ford dealer has a complete line with PCV for around $27. Should fix the problem.
rbhil5
2004 - 2008 F150
23
Apr 26, 2015 10:44 PM
brade
Mar 25, 2015 05:26 PM
Boheefus
15
Nov 29, 2014 06:25 PM
CAPPY00
3.8 & 4.2L V6
Mar 30, 2009 12:58 PM
DELBERT
Feb 15, 2008 05:28 PM
