Coolant temp gauge
Old Jun 3, 2005 | 09:23 PM
wb6anp's Avatar
wb6anp
Coolant temp gauge
I am interested in adding a coolant temp gauge to my pod, but where would the sensor mount and where would an oil temp sensor mount.
Old Jun 4, 2005 | 10:17 AM
Ford_Doctor's Avatar
Ford_Doctor
You are not going to find suitable access for either temperature sensor on the 6.0L Power Stroke.
Diesel Technician Society[/color]
Old Jun 4, 2005 | 10:53 AM
wb6anp's Avatar
wb6anp
Interesting pictures, especially of the failed engine.
Old Jun 4, 2005 | 03:05 PM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
Just a thought, but a bung might be able to be welded to a spare freeze plug and installed in the block.
As for an oil temp sensor, your only reasonable location will be the oil pan itself.
Both of these are a good idea; oil temp on these engines can be quite critical and the factory coolant temp gauge is a real joke.
Old Jun 4, 2005 | 06:22 PM
wb6anp's Avatar
wb6anp
Where do the original gauges get their pickup.
Old Jun 4, 2005 | 08:54 PM
SpartanDieselTech
Former Vendor
Oil temperature sensor is directly in the top of the oil cooler, coolant temp sensor is mounted on the top of the water/oil pump housing on the front of the motor.
Old Jun 5, 2005 | 12:28 AM
wb6anp's Avatar
wb6anp
Can one tee off of these for an after market gauge?
