Its those conti tires again
I have it now. I talked w/Continental today and my tires are not AT. What tires that are quiet doesn't fling rocks up and can withstand road and some gravel will I want and Ford will agree to put on. My fingers are crossed. I pull a two horse loaded sometimes over 5 miles of gravel. I live in Northern CA and have big hills. Annie
Your best bet right now would be the Good Year Wrangler LT 275/65 18" AT/S. Little bit smaller, but the only real choice that a dealer would go for. It changes you speedo reading 3 mph less. Remember you need to change the spare also if they do something for you. As you know, I have the Wranglers and have been pleased so far. Some tire guru will tell you they wear quicker, but nothing is perfect in this world. Good Luck. You can check the tire specs and see a pic on the internet like tire rack .com etc
I unloaded my Conti's on some poor unsuspecting fool for $400. I took them off with only about 250-miles on them to sell them, and put the $$$ towards some BFG mudders 35x12.50x18. I'm happy now!!!!!
https://www.ford-trucks.com/user_gal...oid=72908&.jpg
~~~~~TrekChick
~~~~~TrekChick
TreKCkick
Ok well good looking every thing! I like photos of a great truck, cute driver, hauling two gorgeous dogs! And I admit to trying to blow up the photo just to see what the shirt had printed on it.
Load ratings and side wall ratings: Load range "E" can be very deceptive these days. Few tires are really 10 or 8 or 6 ply any more and the load rating can be as broad as 2900 to 3860lbs and be called "E"
The Conties are rated at 3640lbs single and I think 3440 dual.
There are NO load "E" in 18" that will haul max vehicle axle weight except the Contis and fit the 8" wide rims.
TrakChick would be pushing it with the BFG if she hooked up a fairly heavy 5th wheel. The 35x12.50x18 if I remember correctly, require a 9 to 10 inch rim width and their max load is at 65 or 75psi for 2900lbs> But as long as the two dogs are the primary load, those tires look and handle very good!
Annie your complaint is exactly what mine is, the damned Conties really are terrible on gravel roads.
I seriously doubt you will get Ford to get you new set of five but try anyway...if you don't ask the answer is always no! All I could get was my $250 back because I need the max tow/haul of my F-350 and any other Ford tire was going to lower the capacity of the rear axle by over 480lbs
Originally Posted by Jock
That's one more reason why I ordered an XLT with 17" wheels. the BFG so called "all terrain" are no hell but a lot more aggressive than the Contis. I can't believe they get away with putting an M&S designation on what is no more than an all-season tire.
Now AT indicates All Terrain. Contitracs are NOT All Terrain (as Ford has sold them as). And yes, I can't believe they did that either.
#28
#29
Originally Posted by Fredvon4
TrekChick would be pushing it with the BFG if she hooked up a fairly heavy 5th wheel. The 35x12.50x18 if I remember correctly, require a 9 to 10 inch rim width and their max load is at 65 or 75psi for 2900lbs> But as long as the two dogs are the primary load, those tires look and handle very good!
https://www.ford-trucks.com/user_gal...oid=69280&.jpg
~~~~~TrekChick
P.S. The shirt says "Poison Spider Bycycles - Moab, Utah"
![Wink](images/smilies/wink.gif)
#30
Talking to my Ford GM today.
Originally Posted by Jawbreaker
As of last month, the only tire out there in a 275 70 18" rated E......you guessed it boys and girls Conti A/T TR ...so FMC got a great deal to outfit the O5's with that tire. You can go smaller or go bigger, but the tire on your truck is the only show in town for right now!!!!!
I need to update my information.
