cracked manifold replacement
Old Jun 3, 2005 | 01:06 PM
rlotter30's Avatar
rlotter30
My driver side manifold is completely cracked it half. a friend of mine gave me a pair of manifolds that he said were off a late 70's Ford 351. They look the same from what i can see except that they are much thicker and heavier. Just wondering if anybody knew if this is a direct bolt-on, or if there are minor differences. Also if anyone has any good tips on removing the old one without snapping anything, they would be greatly appreciated. thanks.
Old Jun 5, 2005 | 12:33 AM
Big O Dave's Avatar
Big O Dave
Is your engine a 351? If so, is it a 351W or a 351C or a 351M? That's the place to start. Then you have to find out which of the above the manifolds are for...
Old Jun 8, 2005 | 11:44 AM
dreadinger's Avatar
dreadinger
Where is a good place to get a manifold? My 1973 390 drivers side manifold just cracked in half!
Old Jun 8, 2005 | 01:30 PM
rlotter30's Avatar
rlotter30
thanks i guess i'll just have to have the numbers run off of them to find out for sure if they will fit. As for getting manifolds, i would try your local junkyards. I lucked out and my friend had them just laying around in his garage.
