U. Joint
Old Jun 3, 2005 | 12:11 PM
Big Rig's Avatar
Big Rig
U. Joint
Guys,
I will be changing my oil this weekend and was wondering if I need to lube the Universal Joint? I don't think this has ever been done before...I have a 02 Ex with 27k on her and 3.73 rear end...If I do, how do you do it...Secondly, I want to lube my front hubs with wd40..Where exactly do you spray the hubs...I'm not to mechanically inclined...So don't use big words..
Thanks for your help....
Big Rig
Old Jun 3, 2005 | 02:22 PM
V10_X's Avatar
V10_X
If they are factory u-joints, you can't lube them. They are "non-greasable", no maintenance, factory sealed. You can double check by looking in the middle of the u-joint to determine if there is a grease fitting.
I had to replace mine at 60k miles (I do alot of towing) and I replaced them with greasable heavy duty u-joints.
You have to be careful when spraying the hubs with wd-40. I have heard it can really screw up the bearings if you're not careful. I havent done that, and don't plan on it. I am going to replace my factory hubs with ones from Warn soon. The Ford factory hubs are junk, lots of people reporting problems with them.
Jeff
