Swap an axle
Old Jun 2, 2005 | 12:44 PM
i1dery's Avatar
i1dery
Question Swap an axle
I was wondering what all is involved with converting my TTB
front end on my 89' f250 to a solid axle? any if all drilling or
is it as simple as shoving a f350 axle and rebolting it up to the springs, and does the shaft line up right and tie rods.
Could it be or am i dreamin on this project??
Old Jun 6, 2005 | 02:37 PM
i1dery's Avatar
i1dery
No answers huh?
I guess ill have to??
Old Jun 13, 2005 | 10:34 AM
Redneck 83's Avatar
Redneck 83
It's not too bad of a swap from what I've read. You do need to lift the truck in order to keep the axle from hitting the crossmember. Besides that, you'll just want the steering arms and trac bar brackets from the donor truck and you should be all set for a pretty straight forward swap.. If you search around on here you'll probably find a few posts with more information than I have.
Old Jun 13, 2005 | 11:41 AM
miker67's Avatar
miker67
Do a search under the Offroad and 4x4 forum. There are a bazillion threads on that topic over there. You should be able to glean nearly all the info you need that way.
