Water pumps
Old Dec 17, 1999 | 12:04 PM
mag's Avatar
mag
Water pumps
I think my h2o pump is starting to go. I've noticed a coolent smell, and have small drips starting under the truck. Any recomendations? just get oem or any aftermarket? How easy is it to do yourself? 93 f-150 4x4 302-v8
Old Dec 17, 1999 | 12:58 PM
slik's Avatar
slik
Water pumps
The water pump is fairly easy, remove the fan shroud, fan, then the water pump, scrap the old gasket off, put on new gasket and a little RTV to hold it in place and make a good seal, replace the water pump, fan, and shroud. An hour job if your good at it, 2-3 hours if you go slow and it's your first time.
Slik
Old Dec 17, 1999 | 01:28 PM
Phillip Guidry's Avatar
Phillip Guidry
Water pumps
Before you blame the water pump leaking, verify that is what's leaking.In a dark garage,armed with a decent light,crwal underneath and source out the leak. the water pump will leak from a hole that is near the pulley,visible from underneath. Another possibilty is the themostat bypass hose located on the themrstat housing,visible from above but tends to drip coolant on the timing cover and eventually finding it's way down,very tricky to spot!One more thing, find the drain pipe for the A/C evaperator below the A/C case,visible from underneath on the passenger side. If the end of the pipe shows signs of coolant, it's the heater core that is leaking!Good luck.
Phillip
Old Jan 15, 2000 | 12:04 PM
bassman's Avatar
bassman
Water pumps
hi is it possible to have a bad water pump and still run?
2 freeze plugs on the same side blew out within 1 month-the water was rusty.
noticed that on the first one to blow out.
the temp guage always stays in the cool area
last 4yrs.
now it is overheating,is it pssible for the water to be not(moving at all)
heater core is a yr. old
thanks
Old Jan 15, 2000 | 03:33 PM
Rich's Avatar
Rich
Water pumps
BRONC-OH
1997 - 2003 F150
Nov 21, 2014 10:11 PM
puck1263
Dec 8, 2012 02:11 PM
08duramax
Modular V8 (4.6L, 5.4L)
Jun 6, 2011 03:09 AM
1 good old boy
1997 - 2003 F150
Apr 17, 2006 07:41 PM
kjunone
May 19, 2004 04:19 PM
