Heater control valve
Old Jun 1, 2005 | 11:21 PM
Gary E's Avatar
Gary E
So I am planning on installing one of these, has anyone been really fancy and hooked up a vac operated one? Just looking for hints on where to T into.
Old Jun 2, 2005 | 07:37 AM
mueckster's Avatar
mueckster
I was looking at this last week. Looks like the vacuum line would need to be run thru the firewall to the line at the recirculating air vent diaphragm under the dash below thw glove box. I believe this vacuum line, on the OBS, is under the hood in the far left corner of the engine compartment (when facing the engine). I opted to go with the manual valve to eliminate the excess heat when using the vents after the engine has "heat soaked" after being driven and parked for awhile.
Old Jun 2, 2005 | 10:12 AM
3 of 7's Avatar
3 of 7
I used a manual valve as well. I'm going to install a cable like the old trucks had so I can control it myself (rather than having to turn the air on to be cool)
Old Jun 2, 2005 | 11:58 AM
arninetyes's Avatar
arninetyes
Agreed. The ONLY time I want hot water in the heater core is when I'm turning on the heat or the defroster.
I, too, am setting up a manual cable operation to the valve. I just haven't decided where to put it...
Old Jun 2, 2005 | 12:54 PM
HeatStroked's Avatar
HeatStroked
I have one from the Dieselsite and it is activated by selecting the Max AC and the valve diverts the coolant from the heater core.
Because I live in the SW I've thought about just putting in a mechanical ball valve under the hood and just keeping it closed. I don't need the coolant going through the heater core ever, except a few months a year.
Old Jun 2, 2005 | 02:39 PM
3 of 7's Avatar
3 of 7
I'm going to use the auxilary power plug (looks like a lighter plug ) to the left of the ashtray.....gonna gut that sucker and put the cable there
Old Jun 2, 2005 | 05:14 PM
Gary E's Avatar
Gary E
Well I guess I will just keep it manual if the T into the vac line only closes the valve on max ac
Old Jun 2, 2005 | 06:56 PM
Neil's Avatar
Neil
Lots of us have done this conversion to our trucks. I picked up a electrically operated vacuum switch and a vacuum operated heater valve and added it to my truck. I didn't want to have to be opening the hood all of the time to turn a valve off or on. When I want heat, a quick flip of the switch and its there. It made the AC temp about 5 degrees cooler, and you can have cool outside air coming through the vents instead of 85 degree air on a 70 degree day.
Old Jun 2, 2005 | 07:14 PM
Gary E's Avatar
Gary E
cool, where did you find the electric vac switch?
Old Jun 2, 2005 | 07:23 PM
Neil's Avatar
Neil
I think it was from Vintageair. Give me a while to dig through my papers and I'll let you know for sure. It was a really easy mod.
Old Jun 2, 2005 | 07:28 PM
Neil's Avatar
Neil
Yup, it was Vintage Air Look on page 34 of the online catalog. Since you live reasonable close to me, you are welcome to take a look at how I have mine hooked up. I'm usually home Saturday, Sunday and Monday.
Old Jun 2, 2005 | 10:22 PM
kawika's Avatar
kawika
Neil,
Do you have any pictures of your installation? And how about the part numbers? I can do pretty well installing things with a list of parts and maybe some instructions, but trying to figure out what parts someone would use out of a catalog full of possible parts, nope, not enough money for all the parts that I could incorrectly buy. thanks
Old Jun 2, 2005 | 11:12 PM
Neil's Avatar
Neil
The part number for the Vintage Air Vacuum switch is 11542-VUS. I don't have the part number at the moment for the heater valve, but they are available at AutoZone and Kragen, NAPA etc. I purchased the one that allows the coolant to flow when the vacuum is applied (switch in the cab turned on). It is just a simple in-out valve. I'll try to find the part number for the valve when I get off work tomorrow.
Those two items, some 14 ga. wire, a few wire connectors, a couple of feet of vacuum line, a vacuum "T" and a couple of hose clamps and you are done.
I do have a few pictures that I got from another fella when I did my install. I can send them to you if you'd like.
Old Jun 4, 2005 | 12:11 AM
kawika's Avatar
kawika
Neil,
That would be great. Summertime is coming up fast and It would be nice to have colder AC in the Cab.
Old Jun 4, 2005 | 12:32 AM
Neil's Avatar
Neil
Originally Posted by kawika
Neil,
As you can see, I didn't get the part number posted for you this evening. I wrote myself a note to get it first thing in the morning for you. If you send me your email address, I'll forward the photos to you. You can send it via private message if you don't want the whole world to see your address.
sedly
British Columbia
77
Apr 17, 2008 09:43 AM
Dog_Brains
Dec 10, 2002 12:02 AM
fatdaddy
Jul 24, 2002 07:14 AM
proeliator
Offroad & 4x4
May 23, 2001 01:01 AM
mrgford
Jan 30, 2001 04:28 PM
