1978 - 1996 Big Bronco
starter relay welded closed
Old Jun 1, 2005 | 09:28 PM
ERIK87'302's Avatar
ERIK87'302
My starter relay on my 302 bronco keeps getting stuck in the closed position. I have replaced it three times in the last year. The last one I just installed welded closed after the second start. The only thing I can think it to be is maybe a bad starter motor. anybody know what a typical starter motor should draw? Any help would be appreciated.
Old Jun 2, 2005 | 09:02 AM
BroncoRoadKill's Avatar
BroncoRoadKill
check the ignition switch, they can get old and start sticking. You can pull the small wire off the solinoid and have a friend twist the ignition back and forth while you check the wire for 12v and too see if it sticks.
