oil pan replacement
Old Jun 1, 2005 | 08:13 PM
rusty94f150's Avatar
rusty94f150
oil pan replacement
I have 94 f150 2wd.man trans.4.9 inline six
anybody change rusted pan?
do i need to jack up engine?
Old Jun 1, 2005 | 10:07 PM
1982fordf100's Avatar
1982fordf100
Yes the engine needs to be jacked up to gain clearance for the pan to be removed. Unblolt each engine mount from the K-member, I also unbolted the transmission mount.
Old Jun 1, 2005 | 10:25 PM
IceWagon's Avatar
IceWagon
It says in the Haynes manual that you will need to unbolt the oil pump pickup tube from the oil pump. You will need a replacement gasket for the pickup tube to oil pump. A few guys have said they got their pans out without raising the engine, but you better be prepared to do so. It seems the consensus is to raise the engine.
Old Jun 2, 2005 | 07:19 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jun 2, 2005 | 08:28 AM
4x4fordtrkn's Avatar
4x4fordtrkn
It's a booger
I just recently replaced my oil pan gasket in my 95 F150 I6, 4x4, man trans. It was not as easy as I figured it to be. The engine would not go high enough for the oil pan to come out. If you did manage to get the engine high enough for clearance it would be necessary to remove oil pick up tube to give oil pan room to get out. My oil pan lacked 1/2 an inch clearing the transmission to get out. The engine was stopped in going higher by windshield motor and what appeared to be some kind of vacuum advance unit.
Good luck,
Charles
nissen4
Nov 11, 2016 01:11 PM
mike potts
Sep 6, 2016 12:29 PM
Ruckin69
Jul 1, 2016 05:00 PM
cmb2481
Sep 9, 2015 09:20 PM
66f100
Feb 14, 2005 12:19 AM
