Sponsored by: Auxito
MAF Modification, Need some input
Old Jun 1, 2005 | 03:58 PM
patton's Avatar
patton
I have a 97 F150 with a 4.6L and a manual. I was cleaning the MAF Sensor the other day and noticed that it has a plate that slows down the air that passes through the sensor. I was just wondering if I have a aftermarket intake if removing thiis plate would cause any problems or if it would help. I have seen many aftermarket MAF sensors and none of them have any type of air resistor in them. Any input would be great guys.
Old Jun 1, 2005 | 04:21 PM
Amtek's Avatar
Amtek
you mean by the way the air goes through the front, accross the sensor and instead of flowing straight through, it goes out the top? I would not modify it as it was the way ford designed it to meter air.
Old Jun 1, 2005 | 06:05 PM
patton's Avatar
patton
Why would they make it so you can remove the plate then if they didn't have a reason for it to be removed? Ford also didn't design the f150 for a cold air intake, so that's why I thought maybe it would help. But you do have a point.
Old Jun 2, 2005 | 06:05 AM
Wizardvette's Avatar
Wizardvette
It may not have anything to do with the MAF itself. It may be there just to create turbulence within the intake. Turbulent air = torque. Removing it may result in a loss of low end power.
Old Jun 2, 2005 | 09:10 AM
patton's Avatar
patton
Yeah you guys are probably right. I will just buy a aftermarket one. Thanks for the input though.
