1997 4.2L rebuild
I am new to forums so fogive me for the longhand typing. I have a 1997 F-150 with the 4.2L and lost it to the bad gasket-bent rod problem.
My question is does this problem come back after its been rebuilt.
Another question, I am going to replace all the pistons and the bent rod,
when I pulled it apart the rods where in all different directions. I was always told the bearing tabs faced the camshaft, which would be to the center, does this hold true with this engine.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
