Throttle body
I have a problem with the movement of the throttle valves in their body.
With the engine off and the throttlecable disconnected, it moves in the right way.
But when i fire up the engine, i feel a resistance to get the valves out of the idle position, the rest still works fine.
When i release them they aren't fully pulled back against the idle-screw, i have to use a little bit force.
This all happens after a repair for wich the throttle body has to be removed, the only thing i have done, is cleaning it.
I have sprayed some WD40 in the rotation points of the valves and on the springs, but no use.
Someone has an idea what happened, or a solution to get this tackled?
Oh yeah, it's a '93 E-150 with 351w.
Rudi
