Sponsored by: Kumho
Spongy steering problems
Old May 30, 2005 | 12:41 AM
Gottaford's Avatar
Gottaford
Hi... I just got a 94 F-150 300 I6 the other day and the steering is bugging me. It's like spongy.... drifting from side to side... and it feels like about a foot of play in the wheel to correct it. Is there a way to adjust the play in the wheel or is there something bigger going on in the front end?
Thanks in advance
Michelle's Gottaford.
Old May 30, 2005 | 07:37 AM
holland501's Avatar
holland501
It could be both. Get a big par of channel-lock pliers and crawl under the frontend. Place the jaws top and bottom on the tierod ends and squeez. A new tierod end will have no movement in and out. As they wear, movement will develope. The greater the movement, the greater the wear. You don't have to squeez real hard. Anything more than about an 1/8th of an inch an I would start saving my pennies. While you are under there, have someone rock the steering wheel side to side to check for looseness in the box itself. This should tell you where you stand. Good luck.
Old May 31, 2005 | 12:40 AM
Gottaford's Avatar
Gottaford
Thanks Holland. I'll get to that as soon as I can. So if it's messed up how much does this sorta thing cost so I can start saving? And while I'm saving do I have to worry about the steering going out or something? And if it's not this problem and it's just play in the wheel, can that be adjusted or am I just poop outta luck? Sorry bout all the questions.
Old May 31, 2005 | 06:33 AM
holland501's Avatar
holland501
I can' really say on price. It's been a long time since I had to replace these items. Call someone like NAPA, my favorite around here, for prices. As to the adjustment of the steering box, it is limited. Since the wear takes place on the part of the gear where you drive most, straight ahead, the portion of the gear a 1/2turn to either side is virtually new. When you adjust the slop out of the gears on center, the steering gets real tight when you turn the wheel to either side. Good luck.
Old Jun 1, 2005 | 01:19 AM
Gottaford's Avatar
Gottaford
Thanks so much for your advice. A friend looked under there while I moved the wheel and he said that it looked like my ty rod bushing was going out. Can you change the bushing without changing the whole ty rod?
Old Jun 1, 2005 | 06:59 AM
holland501's Avatar
holland501
Yes you can. Find some reference points for measurements as to length of rod and end. This will get your toe-in close enough so you can safely drive the truck. However you will not get it on the money. If you drive it very much you will quickly ruin your tires. Go directly to an alignment shop and had the front-end re-aligned. Good luck.
Old Jun 1, 2005 | 11:34 PM
Gottaford's Avatar
Gottaford
Thank you so much for your time, and help. These forums are wonderful!!!!!!!!
Gottaford
General Automotive Discussion
19
May 8, 2008 12:39 AM
Gottaford
Aug 26, 2005 07:11 PM
Gottaford
46
Jun 24, 2005 12:11 PM
Gottaford
Exhaust Systems
24
Jun 11, 2005 07:46 AM
Gottaford
17
Jun 11, 2005 01:01 AM
