Check engine: Performance programmer worth it??
Old May 29, 2005 | 10:15 PM
slideways's Avatar
slideways
98 4.6L. 130000+mi Check engine light lit up a little at first and then has become constant. Diagnostic check at my dad's work said Egr system problem. Purchased and replaced EGR valve, reset computer. Light went off for about 3hrs. Then came back on. We arent sure what to check for next and we were going to buy an OBDII scanner for ourselves so we can pinpoint it.
But then the idea came to me to buy a microtuner because they usually do the same thing and we can increase performance/mileage with it for not much more $$.
Thoughts on anything?
Which ones to buy, what could be wrong?
Thanks
Old May 30, 2005 | 12:18 AM
ford390gashog's Avatar
ford390gashog
i don't know if the tuners will let you pull codes they are 400.00 or a obd2 scanner is 200.00
Old May 30, 2005 | 12:26 AM
dnasjc's Avatar
dnasjc
Thumbs up
The DiabloSport Predator will pull codes in the same manner as a code scanner. Plus you gain all the benefits of the Predator in regards to power and performance.
Old May 30, 2005 | 07:26 AM
Greenscobie86's Avatar
Greenscobie86
I think that if you want to try and get some performance out of your truck it would be wise to get the diablo predator. However if you just want to pull codes you probably dont need to pay another 200.00 bucks. Just my .02 cents
Old May 30, 2005 | 07:56 AM
1owner's Avatar
1owner
Thumbs up
I bought the Predator for both reasons. It will pull codes on both my Ford vehicles. It also monitors all parameters that the ecm uses; helpful, if your at that level of diagnostics. The added performance is a plus. I gained about 5% mileage pulling my pop up tent trailer. I get 16 mpg on the highway pulling 2200 #'s @ 70-75 mph!
With my mileage increase, and the ability to read codes, I will see a payback over a few years time!
Old May 31, 2005 | 09:36 AM
slideways's Avatar
slideways
That site you linked for the Predator only listed it for 99+. I guess the computer changed? Mine's a 98.
Is it going to be at least $400? Because i dont think i'll get the approval for an extra $200 to bump performance a tad. I'd probably be better off with the scanner and an FIPK or something.
Any other thoughts on what is actually malfunctioning?
