Blend door Problem
I did the blend door fix in Nov. of this past year, because I wasn't getting heat. I did it and the heat worked fine, but now I have no cold air. I'm not sure why that is. The actuator moves fine. Im not sure if i put the pin is in the wrong spot or the door is completely broke.. If anyone can tell me what I can do I would appreciate it. Its getting hot here
Thanks,
Chris
