I got a 10.25 rear axle that I had the carrier out, went to re-install it and can find the torque specs for the carrier main cap bolts. And on a nother note, with a 10.25 is it pretty common for gear oil to leak out through the pinion-yolk splines? -Paul
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
