Fuel Relay 2000 Explorer
Old May 29, 2005 | 10:26 AM
timmyndebbie's Avatar
timmyndebbie
Angry Fuel Relay 2000 Explorer
Can anyone tell me where the Fuel Relay switch is for a 2000 Explorer?
Thanks, I have pulled carpet and took all 4 seats out no luck.. Help
Old May 29, 2005 | 10:44 AM
bigbuick's Avatar
bigbuick
If your looking for the fuel cut-off switch it's in the pass front kick panel, you have to remove the plastic cover to see it but you may be able to reset it without taking it apart.I believe the fuel relay is under the hood in the relay and fuse box.Location is in owners manual.
Old May 30, 2005 | 08:14 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome timmyndebbie, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old May 30, 2005 | 02:19 PM
marragtop's Avatar
marragtop
Bigbuick is correct. The inertia switch is in the passenger kickpanel area, and the FP relay is in the power dist box under the hood. What problem are you having??
