1997 f-150 front dif
Old May 28, 2005 | 10:38 PM
cleevesj's Avatar
cleevesj
Question 1997 f-150 front dif
I just put 4.56 gears in my 97' f-150 however when putting the front end back together, the slip ring that slides when the vacuum pump is activated to engage the axles into 4 wheel drive fell out. I can not remember which way it was in there. I put in in both ways and will work both ways but which way is correct. The cone end toward the differential or the cone end toward the passenger side wheel???
